NFS Shift 2 with memory driver
Postby thaparser » Sat 4. Jan 2014, 14:48
hello,
I'm trying to extract some info using the cheat engine and found the static value for the gear.
I have inserted it in the extractor mem driver 2420 as seen from the cheat engine 2421 but the extractor and converter doesn't get it properly 2419
any idea what I'm doing wrong?
one unexpected behavior is that for the same address, if I use it as normal I get that big negative value whereas if I use it as gear it shows 0 (might be because gear type converts it to unsigned).
thanks in advance!
thaparser
Images: 26
Has thanked: 5 times
Return to Extractor questions
