Page 3 of 3
Re: X-SIM 360° 3DOF Flight Pit with XPID and VR!
PostPosted: Mon 26. Aug 2019, 01:31
by asticher
Re: X-SIM 360° 3DOF Flight Simulator with VR
PostPosted: Thu 13. Feb 2020, 13:57
by asticher
https://www.youtube.com/watch?v=4k_nAvMY7MI
A real life pilot took the flight simulator and put the pedal to the metal :eek:
No one's ever flown that hard, seriously. If you ever tried to fly in DCS under bridges or through the Burj al Arab, you know what I mean. The guy has never tryed VR glasses before, has never flown the L-39, has never practiced these maneuvers before and flies in the MotionSim as if it's a walk through the park!
PostPosted: Wed 19. Feb 2020, 14:06
by asticher
PostPosted: Fri 28. Feb 2020, 13:50
by asticher
Some say there are no negative or side forces while flying:
Now tell that again :-D
https://www.youtube.com/watch?v=aR-fA6OG21w
This video perfect shows how strong all forces in real live are (in aerobatic or millitary maneuvers).
It looks to me that negative forces are the worst, but also sway/side forces.
PostPosted: Tue 14. Apr 2020, 01:54
by asticher
PostPosted: Mon 27. Apr 2020, 20:00
by etundidor
He asticher,
Awesome work you have done there, hope it is working well * Regarding it I have just a couple of questions:
Regarding your quote:
"Some Frame specs:
Pitch Axis shaft drive: d=80mm ; t=10mm; l=1200mm
Roll Axis shaft drive: d=60mm ; t=20mm; l= 300mm
Gears- and Accurators shaft drive: d=25mm (minimum!)
Pitch Axis frame round tube: d=140mm ; t=4mm (minimum!)
Main- and Roll Axis frame L-Profil: 40mm x 40mm x 4mm (better would be 30x30x4mm square profil!)
I use a big double chain for the Pitch axis. It is much easyer to assamble and to get the perfect gear ratio.
Also it is safer, sturdy and your gear box has less stress. The little more weight doesn´t really matter.
For the roll axis i use a direct drive axis through the gearbox. This reduce weight, latency, adds stiffnes, but ratio can´t be changed.
The Pitch axis has a one side bearing (U-Frame). This reduce roomspace but adds much weight and is not easy to build...ok and it looks just better *g.
Do you think it is possible to reinforce your post by adding some detailed pictures where we can figure it out from where you are taking some of the measurements there? You know for those of us that don´t got those skills and want to replicate your project???
Also, at least for the Roll Axis frame, what do you thing about those new Extruded Aluminum profiles, picture example attached?? Do you think they can be strong enough for the duty??
Again, great work there budy.
Take care
Falcon00
PostPosted: Tue 28. Apr 2020, 12:31
by asticher
No, don't use aluminium, it can break very sudden and without warning (also most plastics).
Wear and tear is a saefty issue - even with steel. But with steel you mostly hear and feel it before something goes really wrong.
About the measurements: This are minimum sizes for proper safety. Everyone with Mechanical engineering knowledge should know what i mean.
Unfortunately, I cannot publish construction plans: The risk of someone accidentally killing themselves through misuse is too high.
PostPosted: Sat 9. May 2020, 23:50
by asticher
PostPosted: Sun 14. Mar 2021, 10:25
by blackjackkkk
where did the details gone ??
PostPosted: Fri 4. Jun 2021, 19:09
by daniel1957
Hi Asticher,
First very good job!
Please could you tell me which references of motor you use?
or if you publish a full list of components ?
Awaiting your reply,
regards
